rt tb
Old May 8, 2009 | 11:32 PM
bjsharp85's Avatar
bjsharp85
Default rt tb
Hey guys. What size throttle body can i put on my r/t mtx with out mod. What vehicle do you suggest i take it out of?
Old May 8, 2009 | 11:56 PM
Captansavaho's Avatar
Captansavaho
depends how much you want to spend you could use one off an ATX neon it is 52mm rather than the 49mm or howellautomotive i think sells a 55mm or modernperformance.com sells a 60mm suggest that if your going turbo or gonna put some major upgrades
Old May 9, 2009 | 10:18 AM
Altima_wb's Avatar
Altima_wb
i was kinda wondering what the size of the 2.4 tb size is... or if its even possible to use it on our motors.. or if its the same as ours? anybody know?
Old May 10, 2009 | 02:59 PM
sabin420's Avatar
sabin420
Modern Performance...there 60mm will work...If you really want, w/ that throttle body, you can port match your intake manifold to the throttle body, but it will work perfectly fine w/o the port matching.
