low oil presure
Old May 23, 2009 | 11:16 PM
ottoretto's Avatar
ottoretto
Default low oil presure
fellow i just change my oil pump, cuz i had a low presure, but i changed and still the same, what can be in the car wrong?? my brother made the oil change but he didnt change the oil filter, i can be that??
Old May 23, 2009 | 11:30 PM
mmench's Avatar
mmench
idk about your oil pressure.. is the oil light coming on or do you have a pressure gauge in you car.
i just have a question about your sig... how do you have f-350 injectors??? or am i just that drun k rite now
Old May 23, 2009 | 11:38 PM
ottoretto's Avatar
ottoretto
lol... i got big injectors, xD and i got a oil gauge!!!
Old May 24, 2009 | 03:57 AM
mmench's Avatar
mmench
lol. on my car... messed up as it is. reads about 30 lbs at idle. and cruizing and throttle its around 60-75 lbs of oil pressure
Old May 24, 2009 | 12:18 PM
12 volt's Avatar
12 volt
always change you filter when you do an oil change and use the correct viscosity.
whats the pressure at?
Old May 24, 2009 | 01:50 PM
ottoretto's Avatar
ottoretto
when the engine cold idle, 30lbs, but warm engine at 15 o less, and when im reving at 4000rpm do not pass the 40lbs,... after this problem the car at idle cold was at 55lbs
