97 DODGE NEON battery charging problems...
Old May 24, 2009 | 12:07 AM
BenjamminR's Avatar
BenjamminR
Exclamation 97 DODGE NEON battery charging problems...
my alternator and fusible link blew up , i replaced both got a new battery and it worked well for about an hour then the battery light came back on..the tester is reading 12 volts when off and 12volts and decreasing when running i know it should be around 14 volts.. dont know what to do.
any suggestions..
Old May 24, 2009 | 12:32 PM
12 volt's Avatar
12 volt
is there a problem with the alternator wiring?
Old May 26, 2009 | 08:39 AM
dorman68's Avatar
dorman68
Check your battery temp sensor.
Old May 26, 2009 | 05:01 PM
streetracer88's Avatar
streetracer88
you prolly fried some of the wiring or put a short in the wire when it blew
