2.0 stroker??
Old May 27, 2009 | 10:55 PM
justinsanders's Avatar
justinsanders
Default 2.0 stroker??
is the block for a neon the same as the block in a stratus 2.4? i really want a 2.4 badly and i was wondering if i can use the 2.4 rods to make my 2.0 a 2.4 since the bore is the same on the two motors... if that'll work then i'll just buy some stock 2.4 rods and a 2.4 oil pan and a 2.4 crank. maybe oil pump? and sump?
Old May 27, 2009 | 11:22 PM
Ghost Neon 2's Avatar
Ghost Neon 2
2.4L internals will not fit inside a 2.0L. The 2.4L block construction differes greatly from the 2.0L. The 2.4L is taller, hence the longer 2.4L rods. Besides, the 2.4L block is very affordable. Got mine for $100.
Old May 27, 2009 | 11:27 PM
justinsanders
ok thanks alot for clearing that up for me i've done alot of research but never really got the answer. so i can get a 2.4 block for cheap? then what? do i have to get the 2.4 internals or can i use mine? i know i'll need the 2.4 crank correct?
Old May 27, 2009 | 11:34 PM
AMM's Avatar
AMM
the block, crank, pistons and rods are compleltey different from the 2.0 to the 2.4 so u cant interchange parts. also its not the rod that gives u more displacement its the crnkshaft and its "stroke" hence the term "stroker motor" or "kit". the 2.0 has a 83mm stroke while the 2.4 has a 101 mm stroke.
mike
Old May 27, 2009 | 11:38 PM
justinsanders
dam so i would have to get all new or used 2.4 internals. so i might just be better off buying a complete 2.4 motor
Old May 28, 2009 | 09:29 AM
Ghost Neon 2
When you buy the black, it "should" be complete. You should still see the pistons inside the cylinder. Many people get them juck yard, and take them to machine shop to have them checked and cleaned. Cost around $300, depnding on what you are using. Are you building a naturally aspirated 2.4L or a turbo'd 2.4L.In any case, read this:
https://dodgeforum.com/forum/1st-gen...ake-a-nap.html
Old May 28, 2009 | 09:57 AM
12 volt's Avatar
12 volt
just for kicks
http://www.importperformanceparts.ne...star-neon.html
Old May 28, 2009 | 11:18 PM
sabin420's Avatar
sabin420
Now, you can stroke the 2.0 to a 2.2. with a .50mm oversize bore and the stroker kit from Howell Automotive. You will have to grind down the inside of the block under each cylinder to make sure the crank can spin freely. It is a special order item and will take a 6-8 weeks to recieve...well, from what I hear about howell is you gotta wait atleast that long for parts from them.
Old Jun 1, 2009 | 02:00 PM
Altima_wb's Avatar
Altima_wb
you know i've looked at that kit and thought about it but whats the point of stroking to a 2.2 when you can very easily and for a fair amount less just swap in a 2.4 and do some mild work to that...
Old Jun 2, 2009 | 08:15 PM
neoncrazy101's Avatar
neoncrazy101
Originally Posted by 12 volt
When I have to get new plates for my little red 2 door, I want the plate to read "NOT420A" Since I get to use 7 #'s and letters lol.
