timing question
Old May 30, 2009 | 04:39 AM
Captansavaho's Avatar
Captansavaho
Default timing question
is there any way to retard the timing without using adjustable cam gears or is that just the easiest way..maybe timing belt?
Old May 30, 2009 | 12:41 PM
berretta96's Avatar
berretta96
engine management system, MSD DIS II, etc. If you just install you're timing belt a tooth or two off, it will run like crap
Old May 30, 2009 | 02:09 PM
sabin420's Avatar
sabin420
just being one tooth off is 9-10 degrees off. Ideal retarding of the cam for performance reasons should be done 1 degree at a time on an engine dyno until peak performance is acheived.
Old May 31, 2009 | 09:17 PM
Captansavaho
ehh so best i just get adjustable cam gears
Old Jun 1, 2009 | 10:21 AM
Ghost Neon 2's Avatar
Ghost Neon 2
You do not want to cut corners in the timing area.
Old Jun 1, 2009 | 01:10 PM
Captansavaho
yeah true haha...well i should be ordering aem cam gears at the end of this week
