Tach signal
Old Jun 3, 2009 | 05:02 PM
ottoretto's Avatar
ottoretto
Default Tach signal
hello fellows, i wanna know with how many volts works the tachometer on the clusters, now i dont got a pcm for that, cuz im looking if we can retard the signal we can make the car rev higher!
Old Jun 3, 2009 | 08:23 PM
9R/T.4door8's Avatar
9R/T.4door8
well first off i wouldnt reccomend doing that.....the computer montiors the engine speed and alters the spark timing due to higher rpms......if you change it it might not rev very high at all...itll probably pop miss and backfire alot.
Old Jun 3, 2009 | 08:27 PM
ottoretto's Avatar
ottoretto
yeah i know that, but i wanna try, lol! but u know that? about the volts??
Old Jun 3, 2009 | 08:34 PM
9R/T.4door8
well take a volt meter and measure the voltage.....grey with a blue tracer if i remember correctly......then change the size of the wire...that should change the reading.......good luck
