boggs out when it wrams up
Old Jun 18, 2009 | 09:56 PM
dirt neon's Avatar
dirt neon
Angry boggs out when it wrams up
Ok ive changed the coil pack, wires, plugs, pcm, tb and tps and the map sensor. when i first start the car and until it warms up its fine but as soon as it gets a little heat in the motor it boggs out and pops a jerks around. any ideas? Is there anything in the motor itself that could cause that? im stumped on what else it could be.
Old Jun 19, 2009 | 06:06 AM
MarkMcCLouds's Avatar
MarkMcCLouds
i am having the same problem
Old Jun 19, 2009 | 01:05 PM
I_Ride_Neon's Avatar
I_Ride_Neon
coolant temp sensor? or maybe a fuel/o2 problem? Egr issue?
Old Jun 20, 2009 | 12:28 AM
das2123's Avatar
das2123
Fuel pump overheating?
Old Jun 20, 2009 | 06:16 AM
Relentless2.0's Avatar
Relentless2.0
Its your camshaft position sensor. I had this exact same problem with my neon. It's located on the side of the head with 4 10 mm bolts. It cost around 20-25 bucks. 
