k can someone explain these codes?
k got a neon 97 manual it turns over but wont start batterys fine and fuel fine
but get these codes
35.open or shorted condition detected in radiator fan low speed relay circui
37.an open or shorted condition detected in the torque converter part throttle unlock solenoid control circuite
i have no clue what they mean and not got the cash to take it to a garage
mike
but get these codes
mike
Torque convertor code is most likely the culprit. Make sure you wire it per the instructions for the mtx swap , neons.org has a good write up. Also did you switch to a mtx pcm cause it shouldn't look for the torque convertor.
i know the 12 codes nothing to worry about but the 11 is
any way of testing the timing belt to see if it has jumped ?
r any other info on this code?
yeh the engine a dohc
