3.55 vs 3.94
Old Aug 7, 2009 | 01:07 AM
ldiablo233's Avatar
ldiablo233
Well I don't have the Tag plate on the trans to tell which it is(tranny was bought from someone) so can someone with a 3.94 drive at XX MPH in 5th gear(prolly like 65-70) and give me a RPM so I can see where mine stands.
Old Aug 7, 2009 | 09:06 AM
das2123's Avatar
das2123
Around 3000 RPM.
Old Aug 7, 2009 | 02:20 PM
Altima_wb's Avatar
Altima_wb
my dohc sport turns 2700 at 65mph... and a second note i would really like to know somebody with a sohc 5spd what rpm they are turning at 65 so i can get an idea of what the differance is between the 3.55 and the 3.94 trannys
Old Aug 8, 2009 | 12:44 AM
ldiablo233's Avatar
ldiablo233
Well mine does 2700(approximately) RPM at 70 mph,SOHC, so assuming das is right, its a 3.55. Is yours also a 3.55?
Old Aug 12, 2009 | 03:01 PM
Altima_wb's Avatar
Altima_wb
no mine is a dohc sport so its got the 3.94... so let me guess turns around 2500rpm at 65?
Old Sep 1, 2009 | 01:05 PM
das2123's Avatar
das2123
OK, I drove my ACR for the first time in about 2 months. Driving down the freeway I was right at 64 MPH and 3000 RPM. SOHC ACR with a 3.94 tranny.
Old Sep 1, 2009 | 01:20 PM
Altima_wb's Avatar
Altima_wb
ACRs have a 3.94 tranny but they also have a different 5th gear ratio for an even lower final drive... i think its something like a .75 or .72 or something compared to a .85 or something close to that
Old Sep 4, 2009 | 09:58 AM
BlackStar's Avatar
BlackStar
i have a question does the 3.94 fit on a sohc motor, ive been dying to know and noone can answer it for me and i dont wanna go out and buy one and it doesnt fit
Old Sep 4, 2009 | 12:18 PM
Altima_wb's Avatar
Altima_wb
yes it does if you would have read this all the post in this thread you would have found that out yourself...... its a great performance upgrade for sohc guys
Old Sep 5, 2009 | 10:53 AM
Ghost Neon 2's Avatar
Ghost Neon 2
The acr mtx is the same as the r/t. A 3.94 mtx with .81FD. All other dohc 5sp models, including the n/a 5sp pt cruiser have 3.94 with .72FD.
All 2.0L , 2.2L, 2.4L, and 2.5L dodges have the same bell housing bolt pattern. Check the ID tag at the end of the case to be sure you are getting the correct gear set.
