fuel pump fuse keeps blowing
y does these fuses keep blowing???? it calls for a 20 amp fuse and i blew 2 of those so i put a 30 in and it blew that too. it only seems to blow whenever i get on the throttle semi hard. i have turbo 2.4 running 24lb injectors. i only get into 2-3 pounds of boost and it'll blow the fuse depending on how hard im on the gas. i can boost 11 psi if im lightly on the gas but if i get on it over half throttle then it'll blow. i dont even kno were to begin to look.
im thinking about just wiring up a switch on my dash like i did with my radiator fans
