tranny question
is it required to use the mopar atf? or can i use some **** from autozone?
I have always used syncromesh sold at autozone.Pennzoil
i would just use what is says which i beleve is mopar 3
you can use any tranny fluid that is ATF+3
any auto tranny fluid as long as its ATF 3 or ATF 4 i'd recommend the atf 4 seen as its updated and its a synthetic... deff worth the upgrade.... but for sure don't use just any auto transmission fluid... its the fastest way to kill your tranny....
What type of transmission does your neon have?
thats a good question you never did say what tranny you had but seen as you were asking about atf I assumed you had an auto... but if manual you deff need to run syncromesh...
its an automatic
Any ATF+3 or +4 should work as long as it states it's compatible for Chrysler transmissions.
I run atf+3 in both the auto and the manual. :)
