Neon 96, 2 doors: windows ajustment
Old Mar 28, 2005 | 02:00 PM
watben58's Avatar
watben58
Default Neon 96, 2 doors: windows ajustment
Hi, i need to sjust the window driver side but a don't understand the mechanism. If stand outside of the car and face to the window driver, the top right of the glass touch the metal rail just over the rubber. So i need to low down the right side of the glass. I'm sure some of you know to do that. If a thread with pics exist, please let me know. May be someone can explain me ?
Old Mar 28, 2005 | 02:07 PM
casper's Avatar
casper
Default RE: Neon 96, 2 doors: windows ajustment
Take the inside door panel off and you will see bolts on the window mechanism. loosen them and adjust as needed.
Old Mar 28, 2005 | 02:27 PM
watben58's Avatar
watben58
Yes, but there's many bolts inside. Is the adjustment bolts can be see throhg a specific hole ? I'll be able to adjust up and down ?
Old Mar 28, 2005 | 03:28 PM
watben58's Avatar
watben58
If some has the Haynes manual with this issue and want to scan or embed the instruction, i will really appreciate
Old Mar 28, 2005 | 03:47 PM
RayDog26's Avatar
RayDog26
do you want to tilt the window in ?? if so when u take the door panel off there are to nuts on the very top of the door right next to the glass.. loosen those a LITTLE bit and move the glass in or out according to how you need it adjusted.. my passenger side needs to be tilted in cuz on the highway u hear the air coming in around the seal... i just never got around to it cuz the weather has been bad.
Old Mar 28, 2005 | 04:44 PM
watben58's Avatar
watben58
Yes i need to tilt (inside/outside) but also down because the glass knock on the metal rail when shut the door. Actually rainy but at the minute it stop i'll go do this.
Old Mar 28, 2005 | 05:03 PM
casper's Avatar
casper
its not that hard, just play with it till its adjusted right
Old Mar 29, 2005 | 10:09 AM
watben58's Avatar
watben58
Yesterday i did some ajustment. I did the one was most urgent because the glass was touching metal rail. DONE ! About the tension of the window on the rubber, there is 2 jacks screw i have to play with and all should be done.
Old Mar 29, 2005 | 04:56 PM
RayDog26's Avatar
RayDog26
sounds good. if u need any more help let us know.
Old Apr 1, 2005 | 02:01 AM
SlowAssNeon's Avatar
SlowAssNeon
i know it might be a little late since you done some on it already.. but for those who might be wondering, here is a how to on adjusting the door windows:
http://www.neonspeed.com/howto/howto..._windowadj.htm
