nc neons
Old Sep 10, 2009 | 05:35 PM
tundra1183's Avatar
tundra1183
Default nc neons
anyone running a na sohc neon, i have a long tube header,95 cam, 55 Tb, 24p fuel inj, raceing pump, cold air intake- true cat, and inlarged intake and exost ports. any more ideas, beside underdrive pully-getting this.
Old Sep 10, 2009 | 07:28 PM
Ghost Neon 2's Avatar
Ghost Neon 2
First, remove the 24lb injectors. Your car does not need, or can it process the additional fuel the 24lb injectors provide. That additional fuel is leaking down your cylinder walls, making its way into your oil. Gasoline mixed with your engine oil is going to have a negative effect on the lubrication properties of your oil. This will lead to viscosity breakdown and bearing failure. The racing fuel pump is also not needed.
You could use a good tuning. If you have a tuning device, you would see how rich your car is running. A better cam shaft would be helpful as well. An after market pcm or stand alone engine management system would allow a wider range of control over your engine, and the modified parts.
