Installin a Tachometer hard?
Old Jun 11, 2005 | 04:08 PM
casper's Avatar
casper
Default RE: Installin a Tachometer hard?
ORIGINAL: 95neonracer
Ya it comes with instructions. But i bought mine from a friend, so i went down to autozone to make sure i did it right. (I wiggled the inst. out of another tach) LOL But really though i only hooked mine up to one side of the coil and it works fine.... unless your sopposed to idle at 2000.
Most need a full signal, yours must be different.
Old Jun 12, 2005 | 05:34 PM
95neonracer's Avatar
95neonracer
WOW! my mistake I just realized i didn't hook it up to the actual coil, i just hooked it up to a wire on the wire harness connected to the ignition coil. I apologize for any confusion.
Old Jun 15, 2005 | 10:07 PM
casper's Avatar
casper
Yeah thats the wire from the pcm.
Old Apr 3, 2010 | 12:23 PM
Zanko's Avatar
Zanko
Originally Posted by RadarLove
If you've got a '96-up Neon, it's maybe a 30 minute job. Pop up the dash, remove the instrument cluster (4 screws?), tap into the wires you need for power (at the defrost switch), lights (if needed, also at the defrost switch) and tach signal (grey wire with light blue tracer at pin 7, jumper 2 behing the cluster). Put it all back together.
'95 models that didn't come with a tach don't tend to have a useable tach signal at that wire (less than 1%), if there's even a wire there. You'd have to use a MSD tach driver or something similar. Adding the tach driver adds a good 5 minutes to the task...
Best of luck!
Is the grey with blue located on the harness that runs through the fire wall? or the one in the engine compartment?
Old Apr 3, 2010 | 09:45 PM
das2123's Avatar
das2123
Man you revived and old post!!! The wire is behind the cluster under the dash. That is where you want to tap into it at.
Old Apr 22, 2010 | 11:30 AM
Ghost Neon 2's Avatar
Ghost Neon 2
Behind the dash is everything you need.
On the left harness is the light connection. Tap into the orange wire. (white wire)
The other three connection are on the right side:
The blue/white wire is for the key-on power (red wire)
The thinner blue/gray wire is the tach signal (green wire)
The black wire with the orange stripe is the ground (black wire)
