My 98 is blowing the fuel pump fuse, I replace the fuse it is good for a couple of days, then it blows the fuse again. The strange thing about this is it has blown the fuse twice and each time it is when I start to back up. Has anyone experienced this before, any help would be appreciated. There are no trouble codes set in the comp.
You guys were right the o2 sensor wire was rubbing on the axle and shorting out, until finally it broke in two, dead short. Fixed the wire car is running like a champ. Thanks quys.
