Fuel problems!
Old Mar 28, 2010 | 11:31 PM
neon527's Avatar
neon527
Exclamation Fuel problems!
I finally got the MAP clamp to work properly, but now in 1st gear only its real "sluggish" and then it runs normally afterwords. So i thought its was the injectors i was using from the 2.4 non-turbo motor (stratus). I put in the S1 SRT4 injectors and its just dumping fuel like theirs no tomorrow!. With the 2.4 non turbo injectors i am running super lean (15.0 AFR) and with the SRT injectors the car wont stay running. I dont have a return line (spoolboy mod) Any ideas? Such as what injectors u guys are running with this similar setup? is the return line neccesary to relieve some of the pressure from the S1 injectors? Any help would be much appreciated!!!
Fuel system puts out a healthy 48lbs
Heres what i've done so far...
98 DOHC head
97 SOHC block
SRT4 turbo w/mani
SRT4 WGA (4lbs)
SRT4 Forge BOV
SRT4 Boost gauge
DOHC fuel rail
Non-turbo 2.4 injectors (salvage)
SRT4 stage 1 injectors (optional)
Stock Fuel pump
Stock Fuel Pressure Regulator
98 Stock DOHC MTX PCM
Block of EGR
Oil Catch Can
