Speedometer
Old Apr 9, 2010 | 04:42 PM
96NeonNelson's Avatar
96NeonNelson
Question Speedometer
My speedometer in my 96 Dodge Neon isn't working Im not sure if its a speed sensor or if its the speedometer cable? Did anyone else have this problem and if you have any clue that could help me figure it out, Thanks alot.
Old Apr 10, 2010 | 10:42 PM
ottoretto's Avatar
ottoretto
bro maybe its a wire cut in the inside, maybe u cant see it, or the cluster! che put the conector pins
Old Apr 11, 2010 | 12:25 AM
streetracer88's Avatar
streetracer88
the cluster went bad buy another one and it plugs in and play doesnt matter if you have a tach or dont have a tach it will work i know cuz it is a common thing with these neons lol..just one down fall let me know how you make out after you replace your cluster
Old May 13, 2010 | 08:14 PM
96NeonNelson
thanks alot streetracer88 it was the cluster i just soldered it and its working like a charm now.
Old May 18, 2010 | 11:16 AM
coneon's Avatar
coneon
I am having a similar problem but my gas, temp, speedometer, and odometer sometimes works and the trip odometer never works. I read an old post about soldering the back side of the cluster. Will this fix all the gage problems except the trip odometer? I assume it’s stuck.
Old May 18, 2010 | 02:00 PM
bg1995redneon's Avatar
bg1995redneon
It just might and it won't cost you much to try it (if you already have a soldering iron, it won't cost you anything but time). No, it won't fix the trip odo. as that item is completely mechanical.
