Need Help, Trouble Code PO302
Old Apr 12, 2010 | 08:23 PM
brians1bad72's Avatar
brians1bad72
Default Need Help, Trouble Code PO302
I have a 98 Neon SOHC, I have trouble code po302 cyl. 2 misfire. I have changed the plugs and the wires, it still has the miss and throws the code. The funny thing about it is it idles fairly smooth, the miss seems to be under a load, holding the brake car in gear while accelerating. Has anyone ever had this problem before? I checked for spark on #2 cylinder, and it has spark, so that would probably rule out the coil, maybe a fuel injector, Im lost. Thanks
Old Apr 14, 2010 | 01:03 AM
brians1bad72
I need Help.
Old Apr 14, 2010 | 10:43 AM
das2123's Avatar
das2123
Try swapping the injector with another and see if the code moves with it.
Old Apr 19, 2010 | 11:24 PM
Nuklhed074's Avatar
Nuklhed074
also is it an automatic? not positive but a faulty torque converter could cause that if its bad under load..
