99' neon sport skipping in 1st gear?
Old Apr 26, 2010 | 06:58 PM
rmitch47's Avatar
rmitch47
Question 99' neon sport skipping in 1st gear?
This is a strange thing, I was driving and all the sudden the 1st gear started skipping like the cv axle was stripping out! I had this problem last year, but it was because of wore out motor and transmission mounts. I replaced and it stop skipping! Well this time mounts are in good condition. I took out the axles to check the splines for wear, but all looked good... Does anyone have a diagram of this trans, im thinking its in the trans and need try to understand why this is happening! If anyone has a clue why this is happening please help thanks, rmitch47
Old Apr 26, 2010 | 10:58 PM
DOHCgarrett t3's Avatar
DOHCgarrett t3
sounds like the trans is going bad check the fluid levels and check back with the folks at dodge forum
Old Apr 27, 2010 | 11:33 PM
rmitch47's Avatar
rmitch47
No not low on transmission fluid! Let me explain this clearer, when taking off it grinds then if i slow take foot off pedal and take it slow it wont grind! Is it possible it could be a bad torque converter? Thanks Rmith47
Old Apr 28, 2010 | 10:07 PM
Nuklhed074's Avatar
Nuklhed074
a grinding it the trans could be bad bearings but im not sure how automatics are if you had a 5spd i know that problem your explaining in an auto though.... does kinda sound like a torque converter
