throttle sticks help!
Old Aug 18, 2010 | 04:42 PM
fig_neon's Avatar
fig_neon
Default throttle sticks help!
When I shift my throttle sticks in the rpm I shift at, usually in a higher rmp. It dosn't do it all the time. Checked the throttle cable and it reacts just fine. What else could it be?
Old Aug 18, 2010 | 04:43 PM
fig_neon's Avatar
fig_neon
sticks for 6-10 seconds then drops back down
Old Aug 18, 2010 | 09:28 PM
Ghost Neon 2's Avatar
Ghost Neon 2
Possible vaccum leak. Check around your tb, intake tube, and vaccum line for cracks.
Old Aug 19, 2010 | 11:42 PM
DOHCgarrett t3's Avatar
DOHCgarrett t3
yeah thats what i was thing is one of your vaccume lines may be cracked or loose. listen for a hissing or try spraying the ends with a little bit of starting fluid see if the engine revs a bit. Don't use a lot.
