quick question about turbos... maybe dumb but idk so.
Old Aug 21, 2010 | 09:57 PM
tjnorton13's Avatar
tjnorton13
Default quick question about turbos... maybe dumb but idk so.
from wikipedia:
"The primary use of this valve is to maintain the turbo spinning at a high speed. The air is usually recycled back into the turbo inlet (diverter or bypass valves) but can also be vented to the atmosphere (blow off valve). Recycling back into the turbocharger inlet is required on an engine that uses a mass-airflow fuel injection system, because dumping the excessive air overboard downstream of the mass airflow sensor will cause an excessively rich fuel mixture (this is because the mass-airflow sensor has already accounted for the extra air which is no longer being used)"
so if a BOV is place before the TB (seeing neons have the map sensor built into the TB) would allow for the use of a BOV? or would you/i have touse a recyling system?
like i said maybe a stupid question but i couldnt find ne where that answered it... any insight is appriciated. thanks
