Piston to valve clearance
Old Oct 22, 2010 | 01:30 AM
rt98neon's Avatar
rt98neon
Question Piston to valve clearance
I have stage 2 crower cams and was wondering if they would hit a 10.5:1 compression piston. Any input would be great
Old Oct 23, 2010 | 07:30 AM
sapporo's Avatar
sapporo
from everything I read about neon's, all 2.0's will have piston to valve interference even stock. I can only imagine when you increase compression and put in a bigger cam, you'll for sure hit with loss of cam-crank timing. but if you're asking about clearance with increase in compression and increase in cam, no, you won't hit unless you break the belt. I read a guy that had the biggest crower cam, milled his head, dome pistons 14:1 compression on a 2.0 neon and had no problems. the best way to determine an answer, is do what all performance engine builders do. put clay on the pistons, assemble engine, rotate crank, remove head and measure squish on the clay.
