timing belt replacement
Old Oct 26, 2010 | 11:03 AM
atinius's Avatar
atinius
Unhappy timing belt replacement
I need to replace the timing belt in my 98 neon 2.0L. The procedure has the following tasks near the end.
    My scan tool only reads and does not run any diagnostic routines. Is there a way to get the ECM to re-learn the cam/crank whatever without a scan tool and does anyone know the consequences of not running this routine?
    Old Oct 27, 2010 | 08:03 AM
    Ghost Neon 2's Avatar
    Ghost Neon 2
    Does the car start?
    Old Oct 27, 2010 | 09:48 AM
    bg1995redneon's Avatar
    bg1995redneon
    If the battery is disconnected while you are replacing the timing belt (and it should be), the PCM will reset itself to defaults and will automatically re-learn when you try to start it. You don't have to do a thing.
    Replace the water pump too while you are at it. And don't just replace the belt, get a timing kit (includes a new idler pulley(s) too. Water pump is about $40, but if an old one goes bye-bye after you replace the belt, you will be replacing it again.
    Old Nov 2, 2010 | 02:26 PM
    ohioguru's Avatar
    ohioguru
    ya def do water pump and check tensioner. mine went out like 2 days after i did my belt and pump. what a pain
    Old Nov 3, 2010 | 08:12 AM
    atinius's Avatar
    atinius
    Thanks everyone for the tips. The car does start and is actually running well, but it has 188000 so I feel preventative maintenance is in order as a broken timing belt can mess lots of things up and the water pump has to be close to its end of life.
    Old Nov 3, 2010 | 11:01 AM
    DOHCgarrett t3's Avatar
    DOHCgarrett t3
    yes, the pump, tensioner and belt are a pretty easy swap. took me about an hour with all the proper tools. a good pully puller and an impact gun make quick work of things. also a good set of metric sockets. you will need an extra hand when doing the idler pully before that has been pulled make sure you put a small allen wrench through the tiny holes on the tensioner or you will need a vice to press it back in. I got the gator kit which came with a set of pretty good directions.
