problems
Old Dec 7, 2010 | 10:12 AM
ohioguru's Avatar
ohioguru
Default problems
started car today and it cranked a little slow but once it started it sounded like a diesel. held idle fine for about 4 min while i let it warm up. but after i gave it gas then let off it would stall out unless i gave it more fuel. its a mtx. any ideas?
Old Dec 7, 2010 | 03:45 PM
bg1995redneon's Avatar
bg1995redneon
Sounds like you have some vacuum leaks.
Old Dec 18, 2010 | 01:25 AM
ohioguru's Avatar
ohioguru
replaced the coil which was def bad. but the problem is now still there but on a smaller scale and is not constant. i think its only happening when the car has warmed up. and ideas?
Old Dec 19, 2010 | 11:10 PM
DOHCgarrett t3's Avatar
DOHCgarrett t3
Maybe, but I am not 100% on this. There are a few folks that complain about this same thing you are saying. (Heating up then dieing.) The cam or crank sensor was to blame but, I don't remember which sensor it actualy was.
