how much horse power
Old Feb 9, 2011 | 03:17 AM
frankie106's Avatar
frankie106
Default how much horse power
how much horse power or compression ratio can the stock 95 sohc injectors be able to handle if any body knows . for example say i'm running 10.6 cr would the injectors be able to handle the diffrence in cr or would i have to go bigger ?
Old Feb 9, 2011 | 11:17 AM
Ghost Neon 2's Avatar
Ghost Neon 2
All stock injectors function the same. The only difference is the wiring connector. Stock sohc injectors are the same as dohc injectors
Stock injections are fine for any naturally aspirated neon. No matter the compression ratio.
Furthermore, a narrowband or wideband oxygen sensor gause measure the stoichiometric output of an engine. The air/fuel reading, letting you know if and when your car is running lean or rich.
Old Feb 10, 2011 | 01:20 PM
frankie106's Avatar
frankie106
thanks apprecitate it.
