Turbo neon oil leak!
Old Jun 21, 2005 | 07:20 PM
R34TuRbOnEoNbOy's Avatar
R34TuRbOnEoNbOy
Default Turbo neon oil leak!
I have a 1999 dohc neon with hahn racecraft turbo kit and i am having a problem with a oil leak. There is a mass amount of oil (one quart a day) leaking from up inside of the engine inbetween the engine and transmission. You cant see where it is coming from you just see it running off of the back of the engine. It runs off of the metal plate inbetween the engine and trany. If you have any idea how to find out where these leak is please e-mail me or post what you think thank.
[IMG]local://upfiles/8801/1DE25D06FB8740DE92135B7B3146E298.jpg[/IMG]
Old Jun 21, 2005 | 11:50 PM
xdeathwishx's Avatar
xdeathwishx
Default RE: Turbo neon oil leak!
ok... pull your transmission off, and check there..
ive never dealt with neon engines, but underneath the flywheel there should be an oil seal around the crank. its probably leaking from there.
