95 neon overheating
Old Feb 17, 2011 | 04:50 PM
TRTPLAYER's Avatar
TRTPLAYER
Default 95 neon overheating
put a new motor in the car and hooked everything up and took for a test drive and the temperature sensor is not working in the car and when i stopped driving it the overflow had coolant in it boiling and i found a small leak of anti freeze on the ground what do you think could be the problem with the guage in the car not working????? and the other there is no oil in antifreeze.
