Using Seafoam Through a Vacuum Line... Which One Should Be Used?
Old Feb 25, 2011 | 01:50 PM
dukester544600's Avatar
dukester544600
New Member
Default Using Seafoam Through a Vacuum Line... Which One Should Be Used?
If I wanted to run seafoam through a vacuum line which line should I use on this car? To be honest I am not even sure if there is a vacuum line that can be used to do this on these vehicles.
Old Feb 25, 2011 | 03:14 PM
bg1995redneon's Avatar
bg1995redneon
Pull the one connecting to the brake booster. I used it myself. It runs from the front of the Throttle body to the brake booster and is held in place with a spring clip.
When you do it, you cannot just stick it in and let it suck. It will kill the running engine. Just let it suck a little at a time.
Just remember to hook it back up.......
Old Mar 1, 2011 | 12:31 AM
Ghost Neon 2's Avatar
Ghost Neon 2
Doesn't kill mine, but I use a smaller vac line.
Old Mar 1, 2011 | 09:23 AM
bg1995redneon
Which explains why it doesn't kill yours. I use the brake booster line because it is connected straight into the intake.
Old Mar 1, 2011 | 05:30 PM
Ghost Neon 2
All vacuum lines are connected to the intake manifold. The one line to the throttle body still draws in air from the vacuum effect under the throttle plate.
