Changed the rad now the engine light is on and code is 1899
Old Mar 5, 2011 | 08:17 PM
dukester544600's Avatar
dukester544600
New Member
Default Changed the rad now the engine light is on and code is 1899
I have 98 neon sohc and I changed the rad today and now the car is throwing code 1899, why would that be?
Old Mar 7, 2011 | 10:15 AM
bg1995redneon's Avatar
bg1995redneon
P1899 Park/Neutral Position Switch Stuck In Park or In Gear
Most likely, you need to check the wires/connector to the lockout switch as you likely bumped it while replacing the radiator. That or replace the switch.
