95 neon head gasket
Old Mar 26, 2011 | 08:28 PM
hulmule's Avatar
hulmule
Default 95 neon head gasket
I can pick up this 95 neon for $400. but it has a blown head gasket iam told. here's my questions. never worked on one of these. how much money am i getting into?,is it a hard job? all- yes water was in the oil and it was driven for 30 miles so i am told ?? i am told it was never overheaded- who knows .can the head be bad what else? i dont want to put a motor in it. the body is ok. looking for a mileage car. what do they get 30 mpg? just let me know what you guys think about what iam getting into and cost. thanks
Old Mar 27, 2011 | 12:37 AM
das2123's Avatar
das2123
For about $200 you can be up and running pretty quickly. www.modernperformance.com has headgasket kits for you to purchase. You will want to replace the water pump, timing belt and idler pulley at the same time for cheap insurance. Check your local auto parts store and compare prices. www.rockauto.com is where I got my parts from. You will need new head bolts as well.
Pull the head and put a straight edge on it to make sure it's straight and didn't warp due to overheating. Replace the plugs, PCV valve and put some fresh oil in there and enjoy about 30-35 mpg.
