Wheel Noise
Old Apr 26, 2011 | 11:05 PM
DodgeStorm's Avatar
DodgeStorm
Default Wheel Noise
A constant left front wheel squeak, that gets worse when braking...and becomes a grinding/clicking when braking under 10mph. The pads and rotors are brand new, calipers seem fine. Thinking it's a bearing or CV axle.....no idea which one.
Video---
http://www.youtube.com/watch?v=6FVqmEdZkYE
Old Apr 30, 2011 | 01:51 AM
das2123's Avatar
das2123
My guess would be hub bearing. With the car jacked up, can you grab and move the tire side to side or front to back?
Old May 2, 2011 | 08:47 AM
DodgeStorm's Avatar
DodgeStorm
I tried my hardest but it doesn't seem to move at all. It rotates slightly on the axle in park when you try to spin it like normal, otherwise there is no movement.
Old May 12, 2011 | 08:39 PM
DodgeStorm's Avatar
DodgeStorm
Still have it...sounds like a low tumbling, growling sound. The wheel wobbles funny...but I cant hear noise from the wheel well. only from in the car. Could it be the differential?
Old May 13, 2011 | 11:42 PM
hemi4spd's Avatar
hemi4spd
Growl = Bearing
clicking = CV joint
by the Vid im saying half shaft but when you open it up to change you can spin the bearing by hand when shaft is removed to rule out the bearing
but u say you hear squeaking, clicking and growling? maybe shaft AND bearing need to be done
these diffs were known to throw their carrier pin causing a hole in the trans case. but that usually makes a "knocking" sound
