Jeep Throttle Body
Old Jul 4, 2005 | 07:18 PM
gabesn200sx's Avatar
gabesn200sx
Default Jeep Throttle Body
I remember reading somewhere that there is a Jeep throttlebody that would fit the Neon's manifold. I couldn't find it with the search. Does anyone know what model and engine size it needs to be?
Old Jul 5, 2005 | 08:10 AM
RadarLove's Avatar
RadarLove
Default RE: Jeep Throttle Body
Off one of the 6 cylinder late-90's. The atx has the 60mm, the mtx has a 56mm or 58mm. It's not a direct swap. You have to slot one of the mounting holes a tad, swap butterfly shafts, and do some dremel work on the butterfly shaft. Still, tons cheaper than buyin an aftermarket piece.
Best of luck!
Old Jul 6, 2005 | 01:36 AM
gabesn200sx
How about the sensors? Which sensors does it use, mine or the ones that are on it?
Old Jul 6, 2005 | 02:25 AM
RadarLove's Avatar
RadarLove
You'd transfer the Neon sensors over. You'll have to make a hybrid of the IAC though (use the Jeep valve portion in the Neon's IAC body).
