1996 dodge neon electrical problems... really need help
Old Jul 11, 2011 | 05:41 PM
rockerdude's Avatar
rockerdude
Default 1996 dodge neon electrical problems... really need help
i have an 1996 dodge neon 2.0L sohc and it has been haveing some electrical problems... it starts and runs for bout 10-15 minutes then it dies, its not sparking correctly i know that and i originally thought it was the coils fault so i replaced it but that didnt solve my problem. and just the otherday i found out there's not enough electricity making it to the coil... can any one help me find the problem, a wiring diagram would be very helpful
Old Jul 12, 2011 | 10:37 PM
hemi4spd's Avatar
hemi4spd
its not that simple. voltage to the coil comes from the PCM driver.
do you have any codes???, this sounds like a Crank or cam sensor failing on you
Old Jul 13, 2011 | 06:42 PM
das2123's Avatar
das2123
DO the key dance and try and pull any codes.
Old Jul 14, 2011 | 03:12 PM
rockerdude's Avatar
rockerdude
thx i will b wrking on getting codes asap
