engine swap
Old Jul 13, 2005 | 11:12 PM
neon1985's Avatar
neon1985
Default engine swap
ok i read the other post on swapping out a sohc to a dual but what is exactly involved in making modifications to the wiring harness?
Old Jul 15, 2005 | 06:32 PM
Willow9238's Avatar
Willow9238
Default RE: engine swap
to tell you the truth i have no idea, but if you want upgrade and your just swapping engines, then get yourself a DOHC computer and swap a 2.4 l, from other various dodge cars. it will cost u a little mre for various mods, Like some engine mounts but u will get a better result, but idf U already have DOHC engine then just go with that I think its almost a direct swap out.
Old Jul 17, 2005 | 10:20 AM
RadarLove's Avatar
RadarLove
Some of the wire colors differ from SOHC and DOHC and from year to year, as do some of the connectors. The only biggie I can think of is the coolant temp sensor, which is up near the cam position sensor on the SOHC and over by the thermostat on the DOHC. There's a guy here locally that has a DOHC with the SOHC wiring harness, and all I saw was the extended wiring for the coolant temp. I don't think he even had to swap connectors.
Best of luck!
Old Jul 18, 2005 | 01:06 PM
neon1985's Avatar
neon1985
kick *** thanks radar love i've looked at mostly all of the connectors and they look exactly the same so hopefully i'll have done by the end of the month.
