cam sensor wiring
Old Aug 16, 2011 | 12:14 PM
RebelX's Avatar
RebelX
Default cam sensor wiring
need some advice. bought a new camshaft sensor for my mom in laws 95 neon, sohc.
do i splice the wires up the same since i have to update the plug or do i have to swap a few around?
i bought one from Orielly's. its a MasterPro ignition products.
Old Aug 18, 2011 | 02:28 PM
das2123's Avatar
das2123
Color match the wires and you're good. If you can, try to solder and shrink wrap the wires.
Old Aug 19, 2011 | 01:43 PM
bg1995redneon's Avatar
bg1995redneon
The cam and crank sensors are vital to the operation of your car and one of the biggest headaches you will have if you dont solder the wires and shrink wrap them when you splice them.
If you make a connection that later goes bad, you will spend hours trying to diagnose why your car won't start and when you find that it is just a bad/loose/shorted connection, you will kick yourself.
