2.0 sohc (automatic transmission issues)
ok, so i have 1996 dodge neon, it has the sohc 2.0, with the automatic transmission. right after i did my motor swap, (required due to a spun rod berring). my overdrive in my neon stopped working, not sure why. we hooked the wiring harness back up correctly and everything, but it kicks in every once and a while. But since it hasn't been working, all my car does is suck gas and burn oil.. I was told it was an overdrive lockup by my automotive instructor, but it kicks in every once and a while. So i was then told that the tranny fluid might be dirty, so i checked it and it was. So i replaced the transmission fluid, the transmission pan gasket, and the transmission filter. That didnt help. So then i was told it could be my overdrive solonoid. But if its that where is it located in the transmission and how hard is it to replace?? i need answers so please respond asap.
There is no overdrive gear on the auto transmission. There is a lockup torque converter that will engage at highway speeds to save on gas.
I would double check your connections and inspect the wiring. Just because it's hooked up doesn't mean the wiring isn't frayed or shorting out on something.
