so car wont over heat while moving. only when its sitting. but its slow to get warm. so stop lights theres no problems. waiting on a teller at the bank yes. but it wont over heat untill the car has moved. then it will continue to run hot for a max of 4 min then back to normal. changed thermostat to 180. could it be the fans not kicking on? bc i dont hear them, how do i check the fans?
what happens is it overheats. lol. itll touch red before the fans come on. then they still dont come on. and i didnt wanna let it hit red 3/4 way up was high enough for me
If your A/C works, turn on A/C, see if fan comes on. If it doesnt work then forget it.
Check Fuse, if fuse OK, Then it is probably a bad fan motor or a bad fan relay.
Usually the relay has a lot higher chance of failure. relay should be mounted on the left frame behind the radiator.
