gauges for a 95 neon
Old Jul 26, 2005 | 08:30 PM
dj_dark_yuy's Avatar
dj_dark_yuy
Default gauges for a 95 neon
the gauges that r in my car do not have a tach..... can i switch gauges to the ones that have a tach.... cuz ive heard differently.... and i heard sumtin bout a blu wire behind the gauge cluster?????
Old Jul 27, 2005 | 12:43 AM
jimmasterK's Avatar
jimmasterK
Default RE: gauges for a 95 neon
As far as I know, if you get a guage cluster w/ tach out of another Neon, it should work just fine. Or elsewise, just buy a tach at Advance Auto or Auto Zone and wire it up yourself.
Old Jul 27, 2005 | 06:48 AM
RadarLove's Avatar
RadarLove
If you have the grey wire with the light blue stripe on both ends (J2 connector on the cluster and at the PCM), you should have a signal. You can check it with a multimeter to verify. If it's there, a tach cluster from any 1st gen Neon will work.
Best of luck!
Old Jul 27, 2005 | 11:20 PM
casper's Avatar
casper
I know the 95 is a little different, but as far as I know its plug and play. Just get a cluster with a tach.
Old Aug 5, 2005 | 02:33 AM
pimped_neon_RT's Avatar
pimped_neon_RT
Yes, it works just do it i did it and my dad did it!
