auto tranny prob/question
Old Nov 4, 2011 | 07:33 PM
6670argclh6670's Avatar
6670argclh6670
Default auto tranny prob/question
Hey people, im new to this site. my daughters 97 neon is leaking tranny fluid (3speed auto). quite abit actually. it is coming from up in between the motor n tranny.
is it safe to say its prolly the input shaft seal thats leaking? or could there be another component thats leaking?
i read somewhere that if its a bad front pump, it would leak from same area, and give the impression that its a bad seal.
im very handy/mechanically inclined so i have NO prob doing the job, im just trying to gain as much knowledge or info before i go into it.
thanks in advance, tony g.
Old Nov 7, 2011 | 09:54 AM
bg1995redneon's Avatar
bg1995redneon
It is most likely the seal but either way, you have to remove the tranny to find/fix it, so there you go.
Old Nov 8, 2011 | 03:40 PM
6670argclh6670
Question
The front pump seal, is that a hard fix? i know replacing seals are fairly easy, imean, once you've gained access to'em that is!
Old Nov 9, 2011 | 04:55 PM
bg1995redneon
Nah. Seals are nothing.
Old Jan 30, 2012 | 09:30 PM
6670argclh6670
okay, got the trans out, bought the seals, gasket, oring. just tlooking for some input on wherre to start and any suggestions on the repair.
Old Jan 31, 2012 | 09:52 AM
89newbie's Avatar
89newbie
You could check facs here or buy a haynes manual at the Zone. It will get you there, not the best, but it will help you and better than waiting for responses. I always take a lot of pictures as you I tear down, better than memory when you get some delay thrown in on you.
