96 Neon Starter Wiring diagram or pics needed
Old Jan 24, 2012 | 12:20 PM
passenger 57's Avatar
passenger 57
Default 96 Neon Starter Wiring diagram or pics needed
Hi
I put in a new starter on a friends 96 neon and long story short I'm not confident that my wiring is correct. The starter clicks but does not engage and the engine wont turn over. Does any one have pics of the correct wiring for the starter. I've attached a pic of a diagram I found but my car is different from the diagram and does not have the lower plug coming out of the shielded harness. That plug come from a different harness on my car. Any Help will be greatly appreciated.
Attached Thumbnails 96 Neon Starter Wiring diagram or pics needed-starter.jpg
Old Jan 24, 2012 | 06:03 PM
djkooldown's Avatar
djkooldown
Which lower plug are you referring to? The ground strap or the lower plug connected to the start that just snaps in
Old Jan 24, 2012 | 07:31 PM
passenger 57
The lower plug that snaps in. Thats not part of my harness.
Old Jan 25, 2012 | 11:19 PM
djkooldown's Avatar
djkooldown
Hmmmmm.... It's supposed to be bundled in with the Ground and Power cable... can you take a pic of what is in that bundle
Old Jan 26, 2012 | 09:41 AM
das2123's Avatar
das2123
That would be your problem. That plug is what tells the solenoid to activate and the starter motor.
Old Jan 31, 2012 | 08:58 PM
das2123's Avatar
das2123
Digging thru a parts box I have, I found that cable you need. $10 shipped and its yours.
