Engine Compatibility
Old Apr 4, 2012 | 02:13 PM
Deerkiller9991's Avatar
Deerkiller9991
Default Engine Compatibility
I have a 1998 Neon DOHC which threw a rod and popped a hole in the block. I almost have the engine out, waiting until the weekend. My question is can I just go down to the junkyard and get a SOHC and use the block,pistons, crank etc without any problems.
From what I have read on this site, the main difference between the 2 is the head. Also what about sensors etc? Is their any difference in the years between the 1st gen?
What do you guys do to check a motor at the junkyard?
Old Apr 5, 2012 | 02:07 AM
Deerkiller9991
bumpity bump bump bump
Old Apr 11, 2012 | 11:20 PM
Deerkiller9991
6 days and nothing? wow the dakota forums are way better on this site.
BBUUMMPP
Old Apr 12, 2012 | 03:35 PM
das2123's Avatar
das2123
Sorry, I don't always have to time to visit the forums.
All 95-99 1st Gen Neons have the same short block/bottom end. Only difference were pistons and the timing components. Any sensors that are on the block, I would pull with the block as well. I would try and find a 98-99 block as the sensors were more universal in those years. Avoid the 95 blocks and 2003+ blocks. You can use any 96-2002 block.
I have never purchased a block or engine from a junkyard but I guess if I did, I would rotate the engine and pull the valve cover to start.
