Transmission drain/fill photo guide
Old Nov 12, 2012 | 11:15 AM
das2123's Avatar
das2123
Originally Posted by PatTheOne
Ive got the 99 R/T. Just bought a new filler plug as it appeared that i was leaking fluid from that point. I dont know when the or if the fluid has ever been changed so thats my job for this week... How much of the transmission fix did you use? I was thinking of using some as a preventitive measure.
DO NOT USE THE LUCAS OIL TRANSMISSION FIX! Read the whole thread, not just the first post. He experienced issues with the Lucas "FIX"!
If your tranny is shifting fine, leave it alone!
Old Nov 12, 2012 | 01:42 PM
PatTheOne's Avatar
PatTheOne
got ya!..... gear oil only then
Old Jan 4, 2013 | 12:37 AM
bryan62's Avatar
bryan62
This may be a little late for the OP, but the problem is that it's the wrong stuff to put in the trans. The Lucas additive used is for automatics, not manuals. The gear lube is meant for a different type of trans, the Neon manual takes 5W-30 lube. Even good motor oil would be a better choice. If, by chance, this hasn't been resolved, draining a refilling the trans with the correct fluid may well make it shift ok again.
Thanks for the photos, I'm planning on changing mine soon, they are very helpful. If you really want the correct lube for the trans, Amsoil makes a lube that explicitly meets the Mopar spec - it's called Manual Synchromesh Transmission Fluid 5W-30.
Old May 3, 2013 | 05:17 PM
GiorgiK's Avatar
GiorgiK
Hey guys, I know this is a bit old, but I was wondering how your tranny turned out, did you fix the leak or swap it? I also added Lucas to mine and had exact same slight rattling noise as described above, plus hard time shifting sometimes, but that disappears as soon as the car warms up (98 SOHC, 5-speed). And thanks for the pictures!
Old Sep 13, 2013 | 02:49 PM
frankarnone70's Avatar
frankarnone70
Looks like your output shaft seal is leaking
