check engine light
Old Aug 15, 2005 | 04:59 AM
larry38815's Avatar
larry38815
Default check engine light
what does 5 flashes of the check engine light mean? i did the turn off and on thing and it flashed 3 times first then 5 times and repeated 5 times a couple of times. anyone know what the 5 flashes mean?
thanks for any help
Old Aug 15, 2005 | 10:39 AM
catman22's Avatar
catman22
Default RE: check engine light
five flashes followed by another five flashes = code 55 = completion of fault code display on check engine lamp. this is the end of message code.
other code was 35= open or shorted condition detected in the radiator fan low speed relay circuit.
Old Aug 15, 2005 | 11:05 PM
larry38815's Avatar
larry38815
ok thanks alot
Old Aug 17, 2005 | 08:00 AM
RadarLove's Avatar
RadarLove
the flashes are all 2-digit codes set by the computer. There's a list here somewhere I'm sure, as well as just about any manual (Haynes, Chiltons) and also at www.troublecodes.net. They are jsut general codes for general troubleshooting. If you want a little more detail, an OBD-2 scanner will read the 4-digit (i.e. P0432) version which usually provides a little more detail.
Best of luck!
