Fuel sender ?
Old Jun 30, 2012 | 01:34 PM
artmo's Avatar
artmo
Default Fuel sender ?
I have a 95 Neon. Replaced the sending unit and pump assm, but the fuel gauge only reads between a 1/4 and 1/2. I removed the pump and replaced it with another one thinking it was defective and it does the same thing so I pulled it out and manual worked the arm up and down and the gauge work OK. I reinstalled it and has the same problem. Can any one help me please. Thanks Art
Old Jul 3, 2012 | 09:05 AM
das2123's Avatar
das2123
Are the other gauges working properly?
Old Jul 4, 2012 | 07:37 AM
artmo's Avatar
artmo
Default 95 Neon Fuel
Thanks for asking, yes the gauges are working fine. When I removed the sending unit I manually moved the arm up and down and the gauge responded normally. That is where I am at. Thanks again Art
Old Jul 10, 2012 | 02:41 AM
I_Ride_Neon's Avatar
I_Ride_Neon
When you say you replaced the pump, did you replace the whole sending unit? Did you check the pigtail connector for any corrosion?
