check engine codes
Old Aug 23, 2005 | 06:00 PM
tad32287's Avatar
tad32287
Default check engine codes
The car is running as crappy as it ever has
It is a 98 neon r/t
I checked the codes and they read 12, 43, 32
12 is not a big deal but 43 is a misfiring cylinder(s), and 32 is a egr system failure
Has anyone ever ran into this problem, and if so how did you fix this?
Old Aug 23, 2005 | 09:09 PM
kleen's Avatar
kleen
Default RE: check engine codes
Do you have an egr block off plate? Have you tried just resetting the ecu?
