Shudders after 2+miles.... need help
Old Aug 28, 2005 | 02:57 AM
CrashDumy19's Avatar
CrashDumy19
Default Shudders after 2+miles.... need help
My 1995 neon runs like a champ... untill i drive it about 3 miles. i think that its because it has bad o2 sensors, and after they warm up they do this stupid electrical loop thing which stops the proper fuel delivery... other than that i have no idea.
can some one please help me out....
Old Aug 28, 2005 | 08:48 AM
casper's Avatar
casper
Default RE: Shudders after 2+miles.... need help
Ring the codes out. If you don't know how, look in the general section here, under OBD 1. That will tell you how to ring them.
Old Aug 28, 2005 | 01:18 PM
CrashDumy19
ok, ill try that...thanks
Old Aug 29, 2005 | 03:14 AM
RadarLove's Avatar
RadarLove
The regular key on-off-on-off-on works to get the 2-digit codes. 1995 Neons are all OBD-2. If your CEL is lit, just take it to Autozone or some other place that scans the codes for free and you can get the 4-digit code(s) which will help narrow things down a lot more.
Best of luck!
Old Aug 30, 2005 | 05:31 PM
casper's Avatar
casper
ORIGINAL: RadarLove
Best of luck!
I realize that they are OBD 2, but if he used that method in the general section, he would get 2 digit codes and they would not match the P-codes in the OBD-2 section.
Old Sep 20, 2005 | 02:23 AM
CrashDumy19
An update on the whole code thing, i ran them and got 12, not worried about that one, then i got 44-Battery temp sensor volts out of range.... what the hell does that mean, that doesnt sound good at all, give me some help casper
