Window thingy's
Old Aug 29, 2005 | 11:43 PM
Strictlyfocused7's Avatar
Strictlyfocused7
Default Window thingy's
I've got a 95 neon, i happened to have broke off the left window handle, i broke it all the way off up to the copper looking piece so you cant turn it whatsoever, so i stopped at a junk yard and he suggested getting the whole window assembly, 20 bucks, i did it, now i just need to know how it comes out and the new one goes in, i know how to take the door panel off but i dont know where to go from there, as far as i can go is taking the two bolts out around where the handle is, then the rest is a mystery to me, so i guess im asking how do i take the whole window assembly out and replace it?
Old Aug 30, 2005 | 05:19 PM
casper's Avatar
casper
Default RE: Window thingy's
Just take the little "C" clip off the inside of the window crank and put the handle only on. Unless your mechanism is bent, thats all you need to do.
Old Aug 31, 2005 | 12:15 AM
Strictlyfocused7
It wasnt just the handle that was broke, it was the aluminum piece that it was connected to also, so i went to a junkyard and get the whole window alignment thingy, what i did was take the door off and disconnected the lock and handle, then i pretty much unbolted every bolt i could find, then unbolted the window and pulled it out, then pulled out the alignment crap inside the door, replaced it, then put the glass and bolts all back in and then the door cover, now my window goes up again
Old Aug 31, 2005 | 02:46 AM
casper's Avatar
casper
Thats good, glad you got it fixed.
