97 dohc atx shifting weird
Old Oct 4, 2012 | 07:35 PM
Longworthb's Avatar
Longworthb
Default 97 dohc atx shifting weird
Ok just as the title says my 97 dohc atx is shifting weird. It seems to shift through the gears way too fast. For example half throttle or so and it shifts into drive at close to 30 mph. Wondering if it could be a linkage problem?
Old Oct 4, 2012 | 11:25 PM
I_Ride_Neon's Avatar
I_Ride_Neon
Its shifting up to early? Is it downshifting normal if you wot? I would check the kickdown cable and arm make sure its moving properly.
Old Oct 5, 2012 | 08:51 AM
Longworthb's Avatar
Longworthb
It takes a lot to get it to kick down it has to be to the floor before it does so I'll have to check it out. Is it located under the battery box? I'm not an idiot when it comes to cars just my first neon
Old Oct 5, 2012 | 09:29 AM
Longworthb's Avatar
Longworthb
Another question. Just trying to get this neon to run decent. Plugs are white. Tell tale sign of it running lean. Could the donut gasket leak be causing this
Old Oct 5, 2012 | 01:58 PM
I_Ride_Neon
Yes exhaust leak can throw off the o2 sensor making it running a little different air/fuel ratio. I would start with fixing anything obvious and get the car up to par. Then diagnose the issues. Yes under the battery box. May also be time for a service? Trans fluid smell burned? Dark color? or red bright red?
Old Oct 5, 2012 | 02:09 PM
Longworthb's Avatar
Longworthb
Tranny fluid is good. Checked that before I bought it but have no records of when the last flush was or if it was done at all. I plan on changing the donut gasket fixing the flange,changing the motor mount, and flushing the tranny and looking at the linkage
Old Oct 5, 2012 | 06:46 PM
I_Ride_Neon
If the trans fluid looks and smells fine I would leave it alone. Maybe drop the pan and take a look. Then just throw a filter up and 4 qts of fluid or so. Run it, check it in neutral.
