help with 2.0 to 2.4
Old Oct 13, 2012 | 11:56 AM
zilfer22's Avatar
zilfer22
Default help with 2.0 to 2.4
does anybody know if i can use pistons and cylinder head from a 98 2.4 stratus and put them into a 98 2.0 block both are dohc?
Old Oct 13, 2012 | 02:35 PM
I_Ride_Neon's Avatar
I_Ride_Neon
Pistons no. Head yes. The head is the same as the 2.0 head. Only difference is the 2.0 has better cams.
Old Oct 14, 2012 | 02:48 PM
zilfer22's Avatar
zilfer22
That sucks thanks though what if the block was done .20 over I'm hoping for high compression
Old Oct 14, 2012 | 02:53 PM
I_Ride_Neon
More displacement will not raise compression. And no, no matter what you do you cannot use the pistons or rods from a 2.4. Just throw in the whole 2.4, and put your 2.0 cams in it.
Old Oct 14, 2012 | 03:16 PM
zilfer22's Avatar
zilfer22
Hmm ok thanks if that's the case I will just take the head off the 2.0 and put it on the 2.4 block
Old Oct 14, 2012 | 03:17 PM
zilfer22's Avatar
zilfer22
I guess I need a headgasket for a 2.4 too then right?
Old Oct 14, 2012 | 05:01 PM
I_Ride_Neon
The heads are the same, just keep the head on there and throw in the intake cam from the 2.0, I think the exhaust cam is the same also. But if you really wanted to change a head for the same head then I would recommend a new headgasket and head bolts. Some people will use copper spray and reuse the head bolts but I never have.
2.4 swap:
Motor mount adapter, 58psi regulator OR 24lb/hr injectors, 2.4 long block. You will use the sensors and manifolds from the 2.0.
