srt turbo sohc?
Old Oct 27, 2012 | 07:00 PM
ohioguru's Avatar
ohioguru
Default srt turbo sohc?
do you need the dohc for the srt turbo? also is there a walkthrough on this set up or parts list? if so link pls! but i would like to do a cheap turbo on 7psi for my dd. if i can ebay turbo it cheaper then thats the route ill go.
Old Oct 28, 2012 | 02:40 PM
I_Ride_Neon's Avatar
I_Ride_Neon
The srt-4 turbo manifold only bolts to the dohc head. I remember using an older turbo dodge sohc manifold on my sohc neon, not sure if it was modified or not. I actually have a sohc turbo dodge manifold but no head to see if the pattern is the same. Here is a crappy write up I did many years ago that may help https://dodgeforum.com/forum/1st-gen...your-neon.html
Old Nov 2, 2012 | 04:16 PM
ohioguru's Avatar
ohioguru
that manifold you have, what turbo would it fit?
Old Nov 2, 2012 | 10:19 PM
I_Ride_Neon
Chrysler style T3's. They make 2 garretts and 1 mitsu that bolt to it. Also the Garrett VNT which is instant spool up. I have like 10 of these turbos laying around. I also have some srt-4 turbos. You could always use the sohc to dohc adapter plate. But like I said I am not sure if it would work with the older sohc manifold. If you are in the US and pay shipping I would send you the manifold and you could give it a shot. Or send me a diagram with measurements of the bolt pattern and I could check it.
Old Nov 7, 2012 | 12:00 AM
das2123's Avatar
das2123
The srt4 turbo will bolt to a sohc head but you need to have a mattdog adapter plate. They are not made anymore, so you have to troll neon forums to look for one.
Old Nov 12, 2012 | 05:37 PM
ohioguru's Avatar
ohioguru
ya im in ohio. 44906. u close to that? mines a 96 but ill try it. tell me what shipping will be. dont pm me tho i seriously never check that.
